Front hub spindle nut tool
Awesomeness
1,522
Orlando, FL
Does anybody have more info about the socket/tool needed to tighten the spindle nut? What size is it? Part number to buy one somewhere?
I don't see a drawing to make one in the back of the manual, nor do I see a part number called out anywhere.
Thanks!
Awesomeness
1,522
Orlando, FL
Does the "GOV" in the part number specify that it is special? Deeper than a standard OTC1913?
I see commercial ones about 4" deep are easily available? Will those work too?
coachgeo
3,551
North of Cincy OH
came across one on fleabay long time back and ordered it. someone in here took the short one you speak off and cut and spliced it to make it longer I think
Floridianson
2,538
Interlachen Fl.
I would assume so and yes it needs to be the seven inch to reach in over the long spindle. Yea seen where OP's just added more length to a standard 1913.
Floridianson
2,538
Interlachen Fl.
The TM calls for 50 foot pounds then back off 1/4 turn. Then 10 to 20 foot pounds and see if the inner gear plate lines up with the pin. If not do not tighten but you can back off one spline.
I took all of mine to 20 and had one line up perfect the rest had to adjust a tad.
