front leaf spring sizes? searched already
firecontrol86
San Diego, CA
ok this might be a noob question, but i did search on here and looked on a few different sites for replacement front springs. in the wiki it says the front springs are 3" wide X 56" long however, all i can find are 2 3/4" wide springs. i'm not going for a lift or anything for right now i just want replacement OEM springs as mine are definitely due to go bye bye. any suggestions?
Stihl029
Kodiak, AK
Well I am going with you have a M1009 here. You can always contact a spring manufacturer snd have some made is one option. I am likely to go this route since I am going for a little more hieght while retaining the function. I am not into turning a 5/4 ton m1028 into a 1/2 ton from lifting it.
ultim8gamr
Napa Valley, CA
I had a M1008 so i cant give the specifics for the 09 but i'm almost positive that if you find springs for a K5 blazer with a 6.2L diesel you will be set. frames and axles are all the same.
When i did a inch lift i used tuff country HD springs that I think were 3/4ton but i can't remember its been years and the truck was sold.. sadly. But still i believe that the springs should be the same as the civvy k5
jimmy-90
Haymarket Va.
One thing I certianly can tell you is that the front springs are not 56" long. they should be 48" long and the rears should be 52" long. If you go to a spring shop and have them build you a set of stock replacements im guessing it will be alot cheaper than haveing the chevy dealer get them for you. If they are even still available from the dealers. A spring shop will DEFINATELY build you a much higher quality spring than the factory ones or anything you can get off the shelf in the way of aftermarket lift ones too
hobie237
Newark, DE
Just look for springs for a K5 blazer if you have the M1009. It's the same truck. M1009 is just a 3/4T blazer
Actually it's a half ton Blazer. Just like the 1008 is a 1-ton truck. The military rates them at actual capacity of gross less curb, whereas the whole "half ton," "one ton" etc. in regular parlance is just a measure of sizes A, B, C, etc. without much correlation to actual carrying capacity.
