- 34,012
- 1,821
- 113
- GA Mountains
Ryan, i'm thinking for one reason or another, the hobbs switch was gone and somebody put that petcock in there to plug the hole. Still question where the plug went unless the truck was converted from a sprag.
Recovry4x4 said:Sermis, you keep your questions coming and during idle time, read TMs. You'll catch on to this stuff in no time. Be advised! It's addictive and one is never enough!
Kenny was referring to the air pressure operated elctrical switch that powers the underdash light.4x4 said "At about 60 PSI the contact closes and the circuit is complete." So does that mean that if one were to lose air pressure for some reason while the front end was engaged it would disengage when the air pressure dropped below 60 psi or does it require less than 60 to operate?
