Front Marker Light Ground
Sam77
11
Northwest Montana
Howdy!
I'm working on getting all the lights up and running with my rig, and in looking into why the front marker lights weren't working - I found that the positive lead from the bulb to the plug wasn't hooked up at all and the ground lug was also disconnected / broken. I've fixed the connection between the bulb and plug (solder and shrink wrap), but I'm wondering where I can reconnect the ground since the lug was rattling around inside the light compartment.
Here's a shot of inside the light compartment. I'm working on getting all the sand and junk out of there so I can clean things up. Can I put a larger terminal on the ground wire and connect it to the other bolt? I'm assuming this is another grounding area, but I figured I'd ask the experts to be certain.
Or - is there a spot where this should be screwed back into? It looks like it fell out vs rusted off. (sorry for the blurry picture).
Thanks in advance!
-Sam77
Action
1,564
East Tennessee
I have seen a couple different ground setups, depending on type and manufacturer. Turn the lights on and touch the ground to each remaining stud. Bolt it to the stud that lights the bulb.
Milcommoguy
2,388
Rosamond, CA
With all the dirt and mud, a ground rod might work. :funny:
Clean it all up, re-terminate and follow along in the TM. One of those leads is ground # "92_" Markers housing always cruded up too. Got the right idea for the nut plate for the covers.
This might help > Wire 92_ right from the TM. Showing right side. Left more of less same with black out lamp.
TM's....Road map to all the goings on HumV. Good idea to download one. Will save your bacon when the internet goes down. CAMO
Sam77
11
Northwest Montana
Agreed! I have it downloaded and found all the numbers and such - just wanted a sanity check. It’s been a while since I’ve chased electrons and wanted to make sure my line of thinking was sound.
Wire is 92D - which looks a lot like 920. :)
Action
1,564
East Tennessee
Or just take the light from the bucket and see which stud(s) are ground. I think it is only 1 or 2 of the 4 studs connect to the bulb.
