Front passenger side electrical cable?
OBX
378
Moyock, NC
Looking for help identifying a cable coming out of the tunnel just behind the doghouse on the passenger side of my HMMWV... it's been cut, I'm guessing as part of the demil process. What was it connected to? SINCGARS? Anyone know an NSN or part number? Thanks!
Welcome to the forum. It would have been impossible for me to be this far along on my Humvee build If not for all the useful information provided by the SS members. You are fortunate to have found this site, please support it by membership subscription.
That cut cable is 24v, most likely hot! Be careful. Disconnect batteries before removing it. You will need to pull it from bottom of the truck.
On my Humvee, after pulling the cable down through its grommet, I found two red wires inside the cable that were both hot. Where they originate is not visible inside the truck and are connected to the backside of the large 24v lug located in the battery compartment. I carefully capped and taped them separately, zip tying them out of the way in the transmission tunnel, allowing for future use if needed.
Good luck!
Coug
4,241
Olympia/WA
most likely it was a radio power cable.
Without the end on it or a closer look to see what the cables inside look like it's probably 95% or better chance it was for radios.
EDIT: As OBX said, it's likely still connected to power at the batteries, so disconnecting the batteries and removing the cable would be a good idea.
hmmwv-newbie
Arkansas
I was just about to ask the same question I found 2 cut off cables in my new rig, one of them I traced to the battery.
Thank you
juanprado
2,866
Metairie/La (N'awlins)
Radio sincgars or harris, gps, blueforce tracker. laptop electronic gizmo all 24v hot...
Impossible to say as all that is removed at demill and no real way to know what purpose the truck was used for..
I would recommend removing all of it to prevent magic smoke escaping.
spankybear
872
WA
I have a bottle of replacement smoke... Only issue is there are no instructions how to reinstall the smoke . I hear is it next to impossible to reinstall the smoke.
