Front running lights M35a2 ??
harry
Robbinsdale/MN
Any one know if theri should be front running lights on a 1968 M35a2
all of my other lights work , their in no front amber lights , ecpet when blinkers are blinking ,
would be the top bulb in light bucket thats not lighting
thanks for any help Harry
m109guy
27
ON
Not as standard equipment, no. The two front amber lights are only used as turn signals. Though I believe the M35A3 comes with them on the front and rear of the truck.
We had to install them here on our trucks to pass a safety check as well not to be harassed by the transport police.
GoHot229
There is a setting for running lights on the three lever switch in front of your left knee, yes But it will not run along with headlights at the same time, its one or the other. Lights and turn signals or no headlights, running lights and turn signals
gringeltaube
Staff Member
2,389
Montevideo/Uruguay
There is a setting for running lights............, it will not run along with headlights at the same time, its one or the other. Lights and turn signals or no headlights, running lights and turn signals
Question is why so? For convoy- driving, just headlights on ?
I found this to be a problem too: during nighttime it is mandatory here to have running lights, markers AND headlights on, all at the same time. Guess this is required elsewhere, too?
An easy way for me to solve this was by jumping terminals L and H out of the light switch socket. That way with main switch in position SERV. DRIVE and aux. sw. OFF one can have all (non B-O) lights together.
SERV. DRIVE and PARK gives all but HL. Same case should be for main in STOP LIGHT and aux. in PARK, according to my diagram below. But for some strange reason it doesn't work... no running lights! Maybe I'm wrong and the circuits are a little different????? or it's this brand new chin-chu-lin replacement switch......:x
G.
Lieutenant
57
Michigan
I have a deuce that has a different light switch assembly, that is all buttons. Is this covered anywhere?
The wiring is the same. To have your front parking lights on with your headlights, you can bypass the switch and easily run a wire from the trailer connector harness to the front parking light harness. Wire #491 in the front to #21 at the rear.
infidel got me
34
Newberry, Florida
My ft.amber lites are inop w/headlamps on as well.
Can you just jump ft.running lamp[side marker] with ft.amber[park lamp]at harness under fender.
I realize both amber lights would flash,when using turn signals,but euro-cars do this as well.
Would this work or not? I think #20 is the side marker wire,not sure on park lamp wire #.
319
Lieutenant
57
Michigan
I would assume so, but I don't have side marker lights and they are not on my schematic for the M35. Parking lamp wire should still be #491.
Wire #20 appears to be for the blackout markers.
