Buderwuder
- 1
- 8
- Hilliard/Florida
I replaced the spindle bushing on my deuce and cannot find any info on what the clearance should be between the axle and the bushing, and or if it requires reaming. The manual just says if it is bad, replace the spindle. Since there are replacement bushing, there must be a procedure to do this, or at least a chart that has the size and tolerances. I have all the info for the king pin bushings, but nothing for the axle bushings. On a separate note dos anyone know the correct reamer for the king pin bushings and the axle bushings? Thanks in advance for any help in these matters.
