- 10,884
- 821
- 113
- Appomattox, VA
I am trying to get this M200 trailer does for Aberdeen, am having problems with the existing brake lines. The steel brake line compression fittings (they have a name, I can't remember what they are called) have corroded to the brass fittings on the master cylinder, as well as to the inner wheel plate fittings, etc. Everywhere there is a compression fitting, they are frozen. I cannot unbolt them without rounding the fitting, and that's AFTER using Kroil and heat from a propane torch. Any ideas of how I can get this stuff off without destroying the female end of the joint? I don't care so much about the steel brake line fittings themselves, I can make new ones. I just don't want to mess up anything else, or round off the fittings to the point where I can't take them out at all....
