I've had a leak the past few days with fuel drain back. I spotted dripping from the stock Stanadyne fuel base- right from the bottom. The bottom filter bail is warped and only the passenger side of the lower bail applies pressure to the filter to remain tightly seated.
I have a new 1/2" fuel check valve with 3/8" tapered hose fittings on either end; I want to install the valve to be sure the pump remains primed. I am not sure how or what line it would be spliced into.
Please chime in if you can help.
