rookie
- 1
- 0
- portcharlotte fl
What is the procedure to changing out your diesel filter
I don't understand this type of post. All it typically does is create doubt, worry, and extra work for someone else. People 'trust' these forums, since usually they know more than the person cruising through here.You might want to pull the injectors and have them cleaned and pop tested. If your running originals they need it by now.
Kurt
PM Magazine? Your google-fu must be superior to my training, master, I can't find anything of the sort.while you're in there. ^^
i would ignore that. if it's not broken....
Look online. there's a cartoon tech tip for fuel filter replacement. KISS principle using a 10 harbor freight hand vacuum pump.
I think this is what you're looking for [page 2, talks about how to properly bleed the filter]: http://psmag.radionerds.com/images/1/1f/PS_Magazine_Issue_596_July_2002.pdf I had to go to the PS Mag DoD website, bring up the index (first 1990-1999, then the 2000+ index) and ran a search in it for "fuel filter." Wrote down the various issues and pages that were in the list, then I just flipped through those issues until I found it. There's many more articles out there about the filters and different sub-topics. I may have overlooked if there were a good one about how to more easily disassemble it for replacement.PM Magazine? Your google-fu must be superior to my training, master, I can't find anything of the sort.
You wouldn't happen to have that cartoon handy, would you?
-Grasshopper
