jplace1011
- 481
- 63
- Santa Ana, CA
I need some help and advice asap.
I noticed fuel was leaking from the bottom hose of my fuel filter. I removed the Top and Bottom Valves, No. 5 & 17 on the chart, there didn’t seem to be any Seals for either valve. According to the TM they’re should be seals, No. 4 on the chart.
I couldn’t find any new seals. I went to the local O’Reily’s and purchased a box of various O-rings. I put new O-rings onto the Upper and Lower Drain Valves. I freaking stripped the Lower Valve in the process. Noooo! I don’t know if I will be able to find a replacement. I put the Lower Valve back into place, it seemed snug even though it was stripped.
I went to start the engine and it would turn over. So I took the fuel cap off. It still didn’t turn over and fuel was bleeding out of the lower drain valve via the attached hose.
So why isn’t it starting now, what should I do? Am I right in thinking the lower valve is leaking because it’s stripped? Do I need to do something else to get it to turn over?
I could get a replacement fuel filter, the screw on type. I’ve heard mixed reviews, I’m not yet sold. The stock one tells you if there’s water in the system and heats the fuel if it gets too cold. I’m not against the screw on type.
Thank you in advance for any input and advice. I still don’t know very much and it gets very frustrating at these times.
@cucvrus
@cucvrus
