This is the way to go, And the method we use.If you can't figure it out then it's the wrong one. Just get the correct one, a little grease and install with one finger. Not a problem.
I have correct usgi filters with the correct gaskets for $5 each plus shipping. No guess work on the O rings. PM if interested.
Wix is 51458, napa is 1458. They are flat fiber gaskets, not rubber. You need to clean the groove well, start the gasket in on one side and and press it around till you get to the end, press the little bump down with your thumb..... tout fini. JTDo y’all know the wix or Napa part number for the oil filter oring ?
