fuel filter
Brutusdog
Louisville, KY
I need an explanation or direction to where I might find this info about the fuel filter on my M1009. There are three hoses on the filter. One coming up from the bottom is the inlet. Why are there two on the right? Obviously one is the outlet, what is the other? I am sure there is a simple answer, but I cannot find the explanation.
Brutusdog
Louisville, KY
I have noticed that some of the folks that replace the original with a spin on, only have in the inlet and the outlet. If it is a tank return ( which makes sense) how do I deal with this?
HikerMan
Boise, Idaho
I believe I read that spin on filters do not have fuel/water separator or a heating element like the factory one? Not sure, but if so then I have no intentions of installing a spin on. Speaking of that I need to get around to changing my fuel filter :|
doghead
4 Star General /Moderator
1,191
NY
Simply answered if you read the TM.
Wolf.Dose
10
Boehl-Iggelheim, Germany
The serial filter assy is junk. Replace by a somewhat up to date filter system. Modern fuel filters include a water seperation system in the filters. The fuel in water sensor you do not need with these days fuel filters. If you stick to the original stuff it is adviable to change the filter after ar laest 40000 miles
acesneights1
23
20
CT
I was gonna try using a FFM of a 6.5 TD. The square ones we use are prone to leaks and causing air in the fuel.
blackhueys
-11
mn
"The fuel in water sensor you do not need with these days fuel filters" why not my water in fuel light came on about a month ago opened the drain on the bottom of the housing and water came out how would I know this without the light just wondering? I also change my filter once in the summer and once in the winter I figure cheap insurance.
