I just purchased this vehicle last week with a broken fuel gauge. The previous owner said that he had replaced both the gauge itself and the sending unit. He said that he determined there must be a broken wire somewhere but couldn’t diagnose where.
I cleaned the ground connections behind the gauge panel and on the left engine head. All of the other gauges read properly. Disconnecting this wire I have indicated in blue does nothing. Swapping the positive wire and the negative with other gauges that are known to work also does nothing/no change.
