Fuel Gauge reading lower than it should
erasedhammer
61
Maryland
So today I was driving home with between 1/4 and 1/2 a tank left, then a minute later I look back and see it has dropped to below a 1/4 tank (this was all on a flat road with no acceleration/stopping).
I thought this was weird so I went to a gas station to top it off. Filled it up, 15 gallons, I was able to physically see the fuel level, definitely completely full.
Checked the gauge was it was reading only 3/4 of a tank.
What could have gone wrong? Is the sender crapping out?
fsearls92
157
Charleston, SC
On my m35a2 I replaced the sender and the float with no change in accuracy. Every mv I have owned has been this way too. Maybe HMMWV's are different, but just expect to learn how the gauge reads not as it reads.
erasedhammer
61
Maryland
On my m35a2 I replace the sender and the float with no change in accuracy. Every mv I have owned has been this way too. Maybe HMMWV's are different but just expect to learn how the gauge reads not as it reads.
I would accept that, only my gauge was working perfectly for almost a year now and now it's decided to go crazy on me.
Mario
89
Rio Rancho, NM
I'm having similar issue.
When tank is empty (as in dry) the gauge faces 9 O'clock (below empty).
I just filled her up and she only reads 1/2 full.
I know on my Tahoe, I could open the instrument cluster and remove the needle to set it to proper level.
Do I have that option on my M998 or is there a calibration/offset nub/dial that can be adjusted?
pjwest03
37
Vestal/NY
Frequently the sender. If you ground the gauge input it will read below empty. If you just disconnect the gauge input it will read full. Most often it's the float not floating.
Sent from my SM-G930V using Tapatalk
