Fuel gauge
CES 3245th
Boston Ma
1983 AM General M923A1
Fuel gauge needle is jumping back and forth.
Is it that the fuel gauge is no good or is there something else that could be causing the Needle to go to the left and to the right rapidly?
Any advice or help would be greatly appreciated thank you in advance
simp5782
Feo, Fuerte y Formal
9,260
Mason, TN
Check the ground on the tank at the top of the tank. Run a new one. If it's good then do the same to the gauge. It grounds thru the dash. Reground all gauges while you are at it.
