fuel heater
Hasdrubal
Vancouver BC
No heater...how about not giving someone incorrect info, if you dont know what you're talking about. There is a fuel heater in the filter base!
TM 9-2320-289-34 Schematic ; E-20
Hoolio
Painesville Ohio
I haven't had to repair it yet...But, I know it's coming...Yes , there is supposed to be a heater in that filter housing..It would be 12 volt..As the only other 24 volt needs are ; Starter and starter relay and first half of glow plug circuit up to the resistor coils behind the intake manifold..After the coils , it would be 12 volt..
sirleaksalot
Show Low, AZ
I knew there was based on all of the searches I did for info. however none of them made mention to voltage.
thanks for getting me the correct info.
sometimes when we don't really know the answer it is best not to answer at all........
Rich
