Fuel Issues - No Start
gimpyrobb
dumpsterlandingfromorbit!
27,786
764
Cincy Ohio
I understand, been busy trying to put all my crap away from haspin and my girlfriend just moved back from Pa. Looks like you got a good deal though.
7Dust
126
Alvin, TX
PTO shaft has to come out.
Does the Steering have to be fussed with typically?
Will the IP lift out the top or drop somehow out the bottom? Which is easiest?
7Dust
126
Alvin, TX
Think I have nearly everything removed that needs to come out - out. EXCEPT for the IP.
Removed the gear from the front... forgot to mark its alignment so I'm sure I'll pay for that later.
My problem is the hub underneath the pulley? Looks like its press fit to the IP? Can't figure out how to get a puller on it. I haven't resorted to hammering yet.
gimpyrobb
27,786
764
Cincy Ohio
The gear doesn't need marked, doesn't need pulled either, but we are past that now! Anyway, unbolt and pull it out.
Did you line up the disc in the advance unit window?
7Dust
126
Alvin, TX
There is a line on the wheel? in the little square window. The pointer is right on it.
I removed the three bolts holding the unit on but it won't budge. The new unit has a tapered shaft so I figured the hub was pressed on and keeping it from coming out.
Imma hammer on it just a little bit in that case?
welldigger
Benton LA
Did you remove the bolts from the back of the pump. And I believe there are more than 3 on the front. The pump should fall off when fully unbolted.
7Dust
126
Alvin, TX
Three bolts on the back. Out.
Not sure what holds it in the front.
I'm looking at the new pump and can't figure it out.
Three holes holding the back on and a threaded tapered shaft in the front.
7Dust
126
Alvin, TX
1. Hammered lightly on the old IP shaft. The pump moved just a hair and opened up a crack. It doesn't just fall out. Thats all it moves:
http://i9.photobucket.com/albums/a70/ninechaos/7C591B3E-BBF6-4F4F-BDD8-EBD25888DF39_zpsiqvkzsdw.jpg
2. The new pump has a tapered shaft and holds the "hub" I cannot get pulled. I know you guys say the gear and hub don't have to come out - but the IP is taper fit into the hub? I'm not entirely sure this pump is identical. Everything seems very similar but the lower hole on the old IP is threaded and this one is not:
http://i9.photobucket.com/albums/a70/ninechaos/AD6AB0F2-A365-40B1-9F5A-C06E388C4FFA_zpsppdzouzn.jpg
3. Put the bolts back in the hub and tried to pull it off by hand. I turned the IP a little but that shouldn't matter since the gear is removed and the engine itself didn't turn?
http://i9.photobucket.com/albums/a70/ninechaos/7CFB41D5-373E-4A27-9411-62249B44F250_zpsgxgk4nu3.jpg
I didn't even feel comfortable taking the HH head off and now I'm in a world of ****. :(
7Dust
126
Alvin, TX
Had a Lone Star and went back to take a less pissed off look at the problem.
I can see one more fuel line connected. Maybe thats holding up progress but doesn't look like it. Will try again tomorrow. :(
