- 1,726
- 1,829
- 113
- Nova Laboratories, WA
TCW3 will increase lubricity.By the way, Should I add something with the diesel? Someone mentioned this is caused by modern diesel not having the same composition as it did in the 80's. I added a little bottle of yellow liquid carb/injector cleaner. Is this what I should be adding every time?
There are others, and a report was made which shows what improves lubricity the most....
Biodiesel and Optilube XPD were #1 and #2 respectively, but they can be expensive, and TCw3 brought the fuel into the wear specification range. Optilube XL is a newer product and reports are that it's better than biodiesel.
TCw3 is readily available for about $11, and used at a rate of one ounce per gallon, meaning you get roughly 2 tanks for $11, or $5.50 add'l per tank.
Optilube XPD is ~$70 and treats up to 512 gallons... It's an anti-gel, cetane improver, and does a few other things.
For 60 gallons, use 15 oz. So, minimum use would get you around 10 FULL fill ups for ~$70, roughly 7$/tank
However, below 32*F, it's suggested to double the dose, meaning you're paying almost $15 extra per tank, in winter.
Optilube XL is pretty much for lubrication only, and is ~$50 for up to 1024 gallons.
For 60 gallons, use 6 oz to 15 oz. So, minimum use would get you around 20 FULL fill ups for ~$50, or roughly $2.50 extra per tank.
