stranger75
- 0
- 6
- Nashville, TN
Fuel lines along frame rail are dry. Fuel filter base is dry. I think there may be a leak at the lift pump. There is a good amount of wet gook down there. Someone earlier mentioned that a problem with the pump would cause cavitation. I guess this may be the cause of that terrible squirrel noise also.
I can get her to crank (if parked nose down on an incline) after 5-6 glow plug cycles and maybe 4 crank attempts. There is white smoke when I do this.
I know I can bleed the air out of the system by backing out the injectors, but without solving the first problem this won't help much because air will continue to get into the system.
