- 10,350
- 75
- 48
- Meadows of Dan, Virginia
It takes an astounding quantity of fittings to properly run a fuel line.
I'm installing a heated primary fuel filter on the xm757 and the image below is only the feed side, the same number of fittings are needed on the output side.
A fixed coupling is not shown in the picture, which connects the 1/2" tubing along the frame to the flexible rubber hose which runs up into the bulkhead connector to the filter inside the cab. The coupling is welded to a bracket mounted on the frame.
...thought you might be interested.
