Fuel line fittings
FreightTrain
Banned
2,730
13
Gadsden,Al
Does anyone know where I can get an adapter for the fuel line fittings to use AN fittings?Can't find 1/2" Flare to AN fittings?The filter would be easy since it has an adapter with what looks like NPT that I can match up but the fitting at the tank is what is driving me nuts.I want to replace the fuel line from the tank to the primary since it had a hole worn through and my fix didn't.Just gonna replace the entire section is Black stainless braid.
thehaas
matamoras pa
go to hose guy and replace with dot with new crimped end no more drips .once you cut copper line you are to short plus to hard to flare copper with inverted fittings
