Fuel polishing
gimpyrobb
dumpsterlandingfromorbit!
27,791
788
Cincy Ohio
Doc, I might be working on polishing fuel, and I've gotten good at polishing my knob, but...
I wouldn't touch your nuts with WRECKERMAN'S hands!
roflroflrofl
Westex
El Paso, TX
Getting down to 'nuts' and bolts again, is there anything wrong with letting stand waste motor oil in the hot sun and then cranking up about 8 inches above the bottom of say, a 55 gallon drum, the waste oil, and pouring it through a HEPA vacuum cleaner bag for filtration into your fuel tank of a multifuel deuce?
LowTech
162
Arizona
I do have a black 200 gal tank that is in the sun. I use it to separate water, and crud, out of the oil. I have a drain on the bottom on the side (it's like a drum on it's side) that I drain water from till I start getting oil, then I draw from 6" above that to filter.
Don't know about the vac bag.
