- 418
- 0
- 0
- Joseph, OR
Is anyone running a fuel pressure gauge on their multi-fuel? I am trying to figure out what pressure range to use. TM 9-2910-226-34 seems pretty clear at first 3 to 5 psi between the tank and the IP gear pump, then 60 to 80 psi between the IP gear pump and the hyd. head. Then the TM gets real unclear. What is clear is that they are talking pressures while testing an IP on a test bench. I would like to have a pressure gauge in the fuel line after the primary and secondary filters, to monitor the in-tank pump performance and filter condition. Anyone have experience with this?
