Jeepsinker
- 470
- 83
- Dry Creek, Louisiana
Anyone happen to know what the opening pressure, and fully open pressure settings on the factory fuel pressure relief located on the secondary fuel filter housing is?
I finished my spin on filter setup and installed it today, used an aftermarket pressure relief valve recommended by Rustystud that I got from Murcal. Com. What I used is the "Prv 70" which has a crack pressure of 10 psi and a fully open pressure of 70 psi. My concern is that I'm only seeing 20psi at the final filter and it fluctuates. Pressure builds to 20psi, then I can hear the valve crack and my pressure drops down to 5 psi, then back up to 20, and so on. I did go for a six mile shakedown run and didn't notice any decrease in power or throttle response, but I am worried about starving my HH for fuel and destroying it.
It may just be that the 1/8"npt pressure gauge I got from Horror Freight just sucks that bad, but I don't have another way to verify pressure at this time.
At the very least a link to the TM section that lists the info I seek would be of great help.
