That bolt looks like it is above the casting for the rod. On the gas burners, it is directly in line with the casting.ok I found a picture of a 6.2 block and it looks like you can use the bolt also just like the gas engine.
Look at the link and you will see the hole for the bolt that will hold the rod in place.
Teardown 13 pictures from trucks photos on webshots
