Fuel pump fittings
bones1
Southern Maryland
Wow, that's close. If it's 1/2 tubing the one nut on the left will work. Don't know why there is a ferrule on it . Not needed with inverted flare. That could be made to work if 1/2 tube.
doghead
4 Star General /Moderator
1,193
NY
The partstarget link lists a dozen manufacturers and their part numbers.
6 of those are common brand names that should be available in any reasonably sized city.
The nut is a standard nut that should be found locally, quite easily.
Searching is good for the soul...
