Fuel Pump to Fuel Filter Hard line
NateM1123LA
Louisiana
EDIT: FOUND IT AT HPG. Hey guys! anybody know what this line is called? My best research shows a fuel supply line and metal tube assembly but all of the parts I've found aren't shaped like mine. For an 89' M1038. One end is threaded the other end apparently goes into a nylon line just before the fuel filter. Thanks!
Nate
Mogman
8,368
Papalote, TX
I looked at a couple different parts TMs, did not see it, supply to and return from pump yes, all the lines for the IP yes, the line from the pump to the left rear of the valve cover where it jumps to the filter no..
Although I should have one here,,,somewhere
Coug
4,116
Olympia/WA
Wowser, that's a difficult one to figure out.
I am about 90% certain the part you want is referred to as "tube assembly, metal"
The reason it's so hard to figure out is it's not with the fuel lift pump or the fuel filter, but it's listed on the fuel injection pump list, as it runs alongside the line that goes from the fuel filter to the injection pump.
Mogman
8,368
Papalote, TX
Ah so it's #3
Edit, I did look at this, but did not see...
Guyfang
22,319
Burgkunstadt, Germany
The NSN: 4710-01-185-6179 has the following part numbers:
5741611
5578559
4710PL0358010
23500022
Try plugging them in your search engine.
