Kaiserjeeps
- 7
- 28
- North Idaho in the woods
I have my CD in hand and will also look for the answer in there. It's not user friendly and I might get my answer here before I ever find it on the CD.
I just changed the primary fuel filter. I went to fill it with the fuel pump and got nothing. Should I feel the pump running? Should I be able to hear it?
I do indeed have 24 volts to the pump. Not sure why it's not pumping.
It ran fine beforehand with some changes in power levels. That made me want to change the filters since I never have.
Could my motor run without a fuel pump? It's a 69 kaiser multifuel that is turbocharged.
I need to remove about 10 lbs of paint to even get to the screw heads..
I am assuming the fuse is under the top cover... I'll start looking on the CD.
Thx...Al..
Thx...Al..
