Fuel return line ID and return back pressure
Rangatira
14
St. Petersburg, Fl
Can anyone say whether there is an issue with higher return pressure using the the 3.2mm id hose (1/8") versus the a 3.5mm id hose? For the injector return on a MEP803a.
Rangatira
14
St. Petersburg, Fl
There is no problem. Just replacing the lines on one of my units with 1/8" and started asking myself the question. I have had combustion issues on larger engines with very small restrictions in the return line in the past.
jamawieb
567
Ripley/TN
I use the same as Light in the Dark. Its very tight to get on but not problems in the years Ive been using it. Make sure its fuel rated.
