Fuel Sending Unit Access Panel
mccullek
288
Oxford MS
Does anyone have or know where to find the instructions for creating an access panel for the fuel sending unit. I would prefer to create this access versus dropping the tank.
I think the kits come with instructions but I can build my own access cover for a few dollars, so prefer not to spend over $100 for a cover and instructions.
19,755
I found something on this in case anyone needs it in the future. I haven’t tried these measurements yet, but assuming they are accurate. Will update this thread later when I get to it.
Thanks for finding the HMMWV Fuel Tank Access information @mccullek !
I downloaded the images - so that in the future - if they disappear, we have local copies of the information.
mccullek
288
Oxford MS
I have some extra panels if needed.
Thanks for the offer. I should have been more patient, but I just decided due to time and effort I would buy the kit, so I ordered one from the Hummer Parts guy. He seemed to have the lowest cost and most reasonable shipping price.
I’m sure I could have fabricated something, but seeing some pictures of this it’s not very noticeable and I plan to do a paint restoration as well, so believe it would look the best without spending a lot of time and effort. I will update this post with some feedback and images after completing this project.
Below is a link to an interesting option that I considered, but I didn’t want to drop the tank and wasn’t sure I could do the fabricating properly without doing so. For anyone that has the tank out, this might be a nice option.
Speedway Motors Fuel Sender Access Door https://a.co/d/2YkXkEY
T9000
367
California
Here how that opening looks. It gives access to the sender and some of the top lines, it’s not large enough to replace the top gasket.
Mogman
9,569
Papalote, TX
57K3529
Comes with instruction, of course one of the first things the instructions tells you is to remove fuel tank.. :)
I believe some have done it in place though..
About the only thing you can "access" is the fuel sending unit.
AAVP7
262
Dortmund, Germany
I´ve done the cutout with the fuel tank in place, but I recommend to drop the tank.
Those fuel lines at the top of the above photo are VERY close to the body. In my case, the rightmost tube was even touching the body.
I used a kind of Dremel with a depth control ring, so did cut just a fraction more than the alu sheet metal was thick, yet I got a little nick in that fuel tube.
So either drop the tank (just an inch is enough), or cut VERY carefully.
