Hammer
- 396
- 83
- Winlock, WA
Ok, so I was having a hard time starting the 818 yesterday, and when it DID start, it would just SHUT OFF. A little head scratching later I figured it HAD to be the fuel shut off solenoid. I turned the knob and it fired right up!
Anyways, I went to check the wires to the solenoid, and they were black at the nut. I went to see if they were loose and the entire bolt and nut came OUT of the solenoid (sparks included!).
So, what are my options for a replacement or upgraded option for this?
http://www.steelsoldiers.com/5-ton-up/25086-fuel-shut-off-valve-cummins-250-a.html
There is a part listed in that post, but otherwise I don't see many other options.
I personally like to upgrade anything I have to replace. So I was wondering if there was anything available for me on this one?
The manual shut off valve is leaking a little fuel, but from a post on here it looks like I might get lucky and just replace an O-ring to fix that small leak.
Now that I have my newest trailer home, my truck is parked. When the bolt came out of the solenoid, I also got a bit of fuel leaking, so it is deadlined until I get that fixed.
Any ideas or options?
