Fuel Supply Line to Primary Filter Fitting
Computerdoc08
213
Florida
I am working on replacing the copper fuel line on my M35A2 with the original primary fuel filter head mount.
If I figured everything correctly here if what I think I will need to replace the primary copper supply line with new rubber fuel hose:
In-tank pump outlet to filter - 3/4-18 inverted flare male to 1/2in hose barb
Primary fuel filter head 3/4in NPT to 1/2 hose barb
Do those measurements seem accurate to those that have replaced their supply hose?
rustystud
2,388
Woodinville, Washington
Use "nylon" fuel hose (semi-truck air hose) . It wil use the old fittings so no need to replace anything except for new "ferrules" .
