Ferroequinologist
Resident railroad expert
- 4,813
- 748
- 113
- Liberty Hill, SC
Ok, I'm pulling my hair out. Just did tons of work to correct this issue, yet it still occurs
I can let the truck idle and it dies after about 5 min. I can drive it and it dies after .25 miles. Open the bleeder screw on the replacement filter housing, or open the filter drain, and it sucks in air like it is under a vacuum. Take the fuel pump line loose from filter housing, crank engine, and the fuel will shoot out over the passenger fender...
-Brand new tank
-Brand new pickup tube and sock
-Fresh known clean fuel
-Hard lines blown out first each way with air
All new rubber lines, injector hard rubber not likely to collapse
-changed filter a few times
I'm at a loss...
-Brand new tank
I'm at a loss...
