toyrunner95
- 0
- 0
- bonney lake. wa
UPDATE!!!! well here is what is going on currently, any help would be appreciated. I replaced both head gaskets, all the fuel return lines, the coolant temp sensor (I broke it taking out the head) I now have everything back together and got it to start, im back to the same problem if not a worse problem. NOW it idles really rough, when I rev it up it still misses and wont go away like it used to. I checked the fuel routing from the injector pump and everything there is ok, I checked for tightness on the fittings and that's good, I found a leak on the IP and tightened it, which helped. here is the odd part. all of the smoky, blue, black exhaust is coming from the drivers side exhaust. the passenger side is clean. or as clean as it should be. I have loosened all the injector lines on both sides and found it to run slightly rougher when I do so on each one. meaning its getting fuel. WHY IS IT RUNNING ROUGH! everything is still in time. I didn't mess with the supply line to the pump, I didn't remove the pump, all the lifters and rockers are good, I cant figure out what is going on! HELP!!! on a side note, which way should the thermostat face? there was a not on it saying front toward radiator. but I want to be sure. don't say spring in or out, because I cant see the spring.
