Fuel Tank Assistance?
Elijah95
Certified Rookie
1,239
1,195
Georgia
Hey guys, I have one of these 600 gallon fuel tanks mounted on an M1061A1 as a dispenser rig, and I’ve searched and found a thread years ago about rebuilt parts for the valve below. I can’t find the thread again (improper keywording on my part)
This lever on top actuates the fuel valve on the bottom, allowing fuel to flow out and frequently the seals dry up and begin leaking.
Can anyone assist?
snowtrac nome
139
western alaska
they are a standard 2 inch mechanical internal valve you would find on a tanker truck if you want a full rebuild you need to find a manufacture on it most likely it would be a Morison. Usually the only thing that leaks are the o rings in the cross shafts, and for diesel you only need a butyl rubber o ring if you are despising gasoline you might want to use nytrol o-rings
