- 3,923
- 76
- 48
- Comfort, Texas
Our unusual cold temperatures in south Texas has caused several leaks on my deuce. One of these is the fuel tank. After a night of 9 degrees I noticed a small frozen spot under my fuel tank and as it warmed up, I noticed a slight drip spot of the bottom of the tank. The spot was a slight depression or divit (on the outside) and when I scraped it with a small screwdriver, fuel started leaking out. I tried to insert a screw driver in the hole to stop the flow but that did not work and only made it worse. (See pic)
So, the fuel is drained and the tank looks clean on the inside and there was very little sediment in the fuel. Question is, is it possible to braze or weld a patch on my tank with blowing anyone up?
