Chainbreaker
- 2,112
- 113
- Oregon
Found the fuel tank repair thread I mentioned above. Go to pg 2, posts #33 & #36 are what you need to know.
It depends on the pump some will be damaged while others dont care.So as an update, gmg must have gotten in a few. I ordered a new bare tank and I'm pretty sure I got the last one. I have too many other projects going on right now to take the time it would take to repair correctly.
A little off topic, but I have another question... I plan to set up an auxiliary tank at some point. If the auxiliary tank runs out, the pump will run dry, will that hurt the pump?
Sent from my SM-G930V using Tapatalk
Not sure, but remember that the genset is only going to call for Aux Fuel when the Day Tank is down to 1/4 full. So eventually if the Aux tank becomes empty the generator will shut down after it runs out of fuel. That may be a bigger issue in itself if it is carrying an electrical load, such as when connected to house, and it suddenly dies due to no fuel situation....A little off topic, but I have another question... I plan to set up an auxiliary tank at some point. If the auxiliary tank runs out, the pump will run dry, will that hurt the pump?
