halftrack
- 11
- 38
- New Orleans, LA
Anyone knows who sells the in tank electric fuel pump for a decent price? I have seen prices as high as $500, that seems a little high to me.
I've worked on a lot of farm tractors. Every one I've ever seen that didn't have a pump the tank was mounted above the injector pump (gravity flow). The rest have had manual pumps driven off a cam lobe.M543A2 said:Just for information, my son and I have put our in-tank pumps on a switch. We turn it on to be sure we have fuel available to start the truck, but shut it off after starting. The trucks run fine without it running. We have the injection pumps turned up, and there is no fuel supply problem with the in-tank pump off even at full power. We also turn it on for fuel filter air bleeding and water draining.
This contributes greatly to the life of the pump.
Farm tractors do not have an in-tank pump. They rely on the transfer pump on the injection pump to lift the fuel, so this is not a new concept. Fuel draws freely through the in-tank pump on these trucks when the pump is not running.
Regards Marti
