dodjh
- 14
- 18
- Central, MS.
Anyone know where I can find the complete assembly for the fuel tank?
Thanks doghead & NDT...for your posts. I have tried to find one for a W200 & W300...same result.If nobody responded that tells you nobody knows where to find one. I sure don’t. They used to show up on ebay for almost $300. That was years ago that I was looking and gave up. Yes the sender is the same as civilian.
: https://www.dodgeconnection.com/catalog/item/2862767/4096174.htmAnyone know where I can find the complete assembly for the fuel tank?
I appreciate you and everyone else's input...I was going to add the site to the M880 TM PDF section but was hoping someoneWell there you go and stainless to boot! Thanks dodjh!!!!! About to order one.
Eight, followed by a bracket always produces that smiley.... Don't know how the smiley face ended up with Vintage Powerwagons phone number. I tried editing the post several times but it still shows back up.
Okay...never had that happen before...Thank you for fixing-it...good idea to disable the smiley faces...Or, disable smileys.
I agree... in that picture, before locating the new unit, I bought the brass float, sock and a role of rubber gasket material, so now they will go in a box or plastic
