Fuel Tank Sock / Strainer Part Comparison
Wire Fox
158
Indianapolis, Indiana
I was getting ready to overhaul the fuel tank with a fresh cleaning and a new sender, seal, access hatch, and fuel screen. While looking up the fuel screens, I was stunned to see the prices that are out there ($35-75 each). I started with P/N R12338556, but found that it was superseded by P/N 12338556-1. At first glance, both looked to be the same at most locations. But in a final price check, I hit up one of my most trusted suppliers and saw that the parts appeared very different, and appropriately have very different prices ($25 vs $58 ).
R12338556:
12338556-1:
They mark the latter as a "fuel strainer with stopper." Precisely though, does anyone know what it actually stops? To me, it almost looks like a check ball so that if the sock became unreasonably clogged, the check ball would pop open and unfiltered fuel could be pulled in to prevent engine stoppage. Any experts here know for sure?
Retiredwarhorses
3,863
Brentwood, Calif
I actually just did this same research yesterday. The sock has an Ac delco part number, problem is, absolutley no one
has them in stock anywhere. The sock for our tanks does have a fail safe as you describe over the early sock and works pretty much as you have pointed out. Personally, I just order them from HPG, I’d like to find them for half price, but no luck. I just did both fuel tanks in an H1....
Milcommoguy
2,098
Rosamond, CA
Looking at the two, they both do the same thing. Top one HumV standard and it too as the check valve / flapper on the end.
Bottom one looks like NASA built it for the space shuttle.
Either one should launch a HumV. What's in your wallet, CAMO
mturner2003
17
Daytona Beach, FL
Ive rebuilt probably 100 fuel tanks....never seen the -1 in that pic, I will still with the standard sock.
Directed at Retiredwarhorses… cleaning my tank now. My strainer rusted off. The question is, when replacing, does the strainer just slip on? Or, is there something we need to apply to make sure it does not come off? In other words do I just put it on or do I need to use an adhesive? Thanks in advance.
  • Like
Reactions: OBX
Retiredwarhorses
3,863
Brentwood, Calif
Yes, but it can be a bit of PITA to get the sock on, I align it correctly on the pickup tube and push it on till it will stay, then hit it flatly with a mallet to seat it permanently, you will need to hold the pickup tube tightly in your hand close to the end where the sock goes on so you don’t bend or break the braze on the pitting end.
once installed it’s kind of hard for the sock to fall off because it rests against The bottom of the tank.
mturner2003
17
Daytona Beach, FL
10-4. Thank you.
