jrobinson5093
- 0
- 16
- jakin georgia
just thinking out loud here but i wonder if a 250 cummins and a fuller ten speed will fit in a m35a2 and if not will the fuller fit in a m818 tractor?
I'd like to explore the possibility of a transmission swap in order to get more gears, reduce the gaps, and make the truck more highway-friendly. But it's pretty low on my priority list. When I get around to looking into it, if I find that there's nothing that'll fit in there, then I'll go with your OD upgrade.i have to ask why would you want to do this swap? what are you after in the end?
tom
I think that is a two fold problem. Even if the transmission gears were there, it seems like most trucks wouldn't have the power to push a brick that large through the air that quickly. Then you have to solve the problem of a lack of power.I'd like to explore the possibility of a transmission swap in order to get more gears, reduce the gaps, and make the truck more highway-friendly. But it's pretty low on my priority list. When I get around to looking into it, if I find that there's nothing that'll fit in there, then I'll go with your OD upgrade.
