Fuse Block Question - Where to pull power?
Warthog
240
OKC, OK
Fuse boxes are not grounded. The frame and cab are grounded to the battery and almost everything is then grounded to the cab. However you can add an addition ground box to the battery if needed.
soulbrojosh
albion, mi
Thanks Warthog! i think i've got most of it worked out now....just have to replace my oil cooler lines before i do any electrical. friends get upset when you show up to show off your m1009 and leave little puddles in their driveways. Thanks again
