See the orange response.4. Red wire to head light fuse. This is the one I had mistaken as the other red wire. Does this one feed direct to the fuse or does it go into a harness and then from somewhere make its' way back?
It feeds thru the firewall connector directly to the fuse box.
Circuit goes: Fuse box to B/O switch, to headlight switch, back to fuse box, to lights?
Orange wire from the fuse box, to the B/O Sevice Switch (not the B/O light Switch), to the headlight switch, dimmer switch and then to the lights.
I'll double check the feed from the B/O power feed to the headlight switch and see if that solves my issue.
Make sure you are checking the correct switch as the Service Switch has to be on inorder for the headlights to work.
