Hello all;
I am new here and if this is the wrong place to ask,please let me know and I apologize. Anyway, I have had this G204 Hobart welder for about ten years or so. It runs and works great. I usually don't use it much but run it at least 2 times a year to keep it lubed up. I asked my son to please put the battery in it the other day and he hooked it backwards (positive ground). When I started it,it blew the rectifier clean (separated from steel mount) off and lo-and-behold, no more charging. I realize the rectifier is now trashed,but was wondering what else might have gone bad. I test the 3 leads (while running)with a test light and the battery lead lights.then tested both coming from front of engine. One lit twice as bright as the battery one and the other doesn't light at all. Does this mean something else was trashed? I know very little about this. I also have been searching the internet for this part YJ68 with very little luck. I thought I read somewhere on here that someone found them for 13 dollars,but don't remember where. I would really appreciate some info on this. Thank you all very much in advance. PS If anyone might have one of these rectifiers, please let me know.
