Well curiosity got the better of me so I went to the garage. Meter has 200,2000 20k,200k,and 2000k (ohms). Anyway,I hooked it all up and gave it a try. Immediately after turning power on, ammeter shows 15 amp discharge as before. I started it anyway figuring it might go to charging position,but it didn't. I then disconnected the +B connection and ammeter went to zero. Battery wire was hot along with rec quite warm. I tested +B coming out of rectifier (running) and had 12.9v AC. No DC, same as before. Disconnected stator wire from rec and retested,was 19.5v AC to gnd. Still 39.5 AC stator to stator . Just for the heck of it, I tested red wire that was connected to old regulator and showed 122v AC to gnd. I thought that was quite strange,but what do I know. If you test wire coming from ammeter to rec,shows 12v DC. I think the time has come to put it to bed. Biggest thing that confuses me is that battery wire shows 12 v DC. +B from rec/reg should also be (+)DC. But when you connect battery to +B on rec..its a dead short, running or not. I don't get it. Anyway, I really appreciate all the help with this. It is just going to be one of them nightmares. I believe I have been beaten. Thank you so much again...Len
