Garwood Winch Specs
jatonka
87
Ephratah, New York
I know it sounds impossible, but what if someone made a mistake? That's what those last pages in all the TMs are for, no? JT My garwood 10K winches on the front of my deuces won't fit 300 of cable. unless you use sideboards
jatonka
87
Ephratah, New York
the 2 1/2 ton 10000 lb winch still can't hold 300 feet of 1/2" cable and work with it, plus your line pull would be more reduced. so, maybe they meant 200 feet of 1/2" cable which is what is published in many operator and maintenance manuals. back to the 101
emmado22
147
Mid Hudson Valley NY
Like I said, I dunno.. Im just posting info I found online..
I have 250ft of 1/2 inch wire rope on my winch, it barely fits..
But 200 is what is called for in all the modern TM's.
Scar59
41
Mt. Eden, KY
The lube order is covered under the M939 Tech manuals as listed on this site. Lots of good information there.
You will have more questions, the manuals for these vehicles are all there.
(80/90 GO)
DDoyle
80
West Tennessee
While not addressing the drum capacity, TM 9-8617 "Winches, Power-Takeoffs, Power-Divider and Hydraulic Equipment - Gar Wood" is an extremely useful manual for all things winch on the G-742, G-744 and G-749 trucks.
Best,
David Doyle
www.DavidDoyleBooks.com
M35A2
M35A2 w/w
M36A2
M36A2 w/w
Class 530C
M45 with 210G1 compressor
M292A2
M756
M764
M135
M123A1C
M62
CMU-5
Kevin h
New Hampshire
I was wondering if anyone found parts for the Garwood G726 10000 lb winch? I just got one and need seals for the worm gear shaft and gaskets for the case. I found a TM on this site but cant seem to find the parts. Any help would be appreciated
1,177
Site rules request a state in your location.
Try any of the MV surplus parts vendors.
