Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
I know it sounds impossible, but what if someone made a mistake? That's what those last pages in all the TMs are for, no? JT My garwood 10K winches on the front of my deuces won't fit 300 of cable. unless you use sideboards
the 2 1/2 ton 10000 lb winch still can't hold 300 feet of 1/2" cable and work with it, plus your line pull would be more reduced. so, maybe they meant 200 feet of 1/2" cable which is what is published in many operator and maintenance manuals. back to the 101
The lube order is covered under the M939 Tech manuals as listed on this site. Lots of good information there.
You will have more questions, the manuals for these vehicles are all there.
(80/90 GO)
While not addressing the drum capacity, TM 9-8617 "Winches, Power-Takeoffs, Power-Divider and Hydraulic Equipment - Gar Wood" is an extremely useful manual for all things winch on the G-742, G-744 and G-749 trucks.
I was wondering if anyone found parts for the Garwood G726 10000 lb winch? I just got one and need seals for the worm gear shaft and gaskets for the case. I found a TM on this site but cant seem to find the parts. Any help would be appreciated
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
