area52
- 5
- 38
- San Bernardino CA
I have been doing some research on converting a gas powered M246 wrecker that I found, over to a LDS multifuel. I found a decent deal on the engine/tranny and he can throw in a deuce transfer air shift also.
Here is a list of things to change, anything else anyone can add?
gas tank/fuel pump
radiator/hoses
motor mounts
oil/temp senders
inlet filter housing/piping
exhaust stack/manifold
fuel lines
air lines
tach
redo throttle/engine kill linkage
I have to go back and climb under it to see about the PTO's and what is gonna work.
Currently there is no winch(but it does have the pto), but I plan on putting one in if I do this.
anybody add some advice/hints
I read Kenny's conversion on his 108 and will probably follow alot of what he did, hopefully!
edit: the LDS engine has all the accessories on it already so thats a plus.
gas tank/fuel pump
radiator/hoses
motor mounts
oil/temp senders
fuel lines
air lines
tach
