TurboLSHumvee
- 5
- 3
- Southern Californa
I thought you guys might appreciate some of the work done on my humvee.
Here is the video the guys made who did the LS/4l80 swap:
Since then I have changed a few things around. Once I get this tune figured out I should be conservatively around 600 hp.
Below is some of the early fitting and fabrication:
I ended up having to replace the transmission/oil cooler as there was not much room under the hood with the intercooler stacked on top.
